BLREC log files
Discussion in 'Windows' started by RussRiopelle, May 16, 2014.
  1. RussRiopelle
    Feb 4, 2014
    38
    Does anyone know why I would have over 200 of these files in directory C:\ProgramData\3CX\Data\Logs.
    Any information at all would be appreciated.....
    Thanks....
  2. roland_3CX
    roland_3CX New Member
    Mar 28, 2014
    131
    7
    Hi Russ,
    Ensure that the "keep backup of log files " option is checked. Settings >> Advanced>> logging level.
  3. RussRiopelle
    Feb 4, 2014
    38
    That was not checked on mine. I checked it off.
    Is it safe to just delete most of the files?
  4. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Yes, is safe. You can view them with the binary log viewer, an optional app to use.. but else you can toss as you see fit.
    I believe I wanted some, but may have just added a nightly prune task (forfiles..).. but don't recall.
  5. RussRiopelle
    Feb 4, 2014
    38
    Thanks for the response.
