Bluetooth Headset not available / does not show
Discussion in 'Windows' started by dbergsma, Jul 6, 2009.
  1. dbergsma
    Oct 27, 2008
    39
    3cx softphone 3.1.6288.0 does not show plantronics 9xx headset in preferences.
    It does appear in windows / control panel,
    windows speech recognition works with it,
    Gotomeeting can use it.
    Softphone, Preferences - it does not appear in the list of devices.
    Using freeware version, everything patched up to date.
    Cheers
    Dean.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,485
    67
    Hi Dean
    Dean, please do a right-click on the sound icon next to the clock in the taskbar, and open "Volume control" window. There, from menu open Option/Properties dialog. Expand the "Mixer device" combo and check if Plantronics device is listed there - 3CX Voip Phone recognize audio devices in the same way as system Volume Control does.
    Regards
    vali
  3. dbergsma
    Oct 27, 2008
    39
    thanks Vali,
    sadly -- it doesn't appear. I recognize this isn't a 3cx issue -- however, hoping that you know -- any idea how to make it appear?
    thx
  4. Vali_3CX
    Dec 12, 2008
    1,485
    67
    Hi, Dean
    I'm not very skilled in such kind of things, I suppose the drivers you mentioned be not real drivers, but some Direct Show audio filters, which can be recognized and used by certain programs. As I said, is just a supposition. However, if true, we don't provide such support in our current implementation. I don't know in the future, but definitely for now and the near one - no.
    Regards
    vali
  5. dbergsma
    Oct 27, 2008
    39
    my bad -- playing around with sound settings in windows -- eventually recognizes headset.
    once that happens, 3cx is happy with it.
    my goof.
    d,.
