Bogus IP header length (0, must be at least 20)
Discussion in '3CX Phone System - General' started by nexsip, Dec 20, 2007.
  1. nexsip
    Sep 17, 2007
    21
    dunno what the deal is, just tried to upgrade a customer to 5.0.3752.
    See and INVITE then a TRYING then the UDP stream send a lot of:
    Bogus IP header length (0, must be at least 20) to the ITSP.
    dunno if that 3cx or not. rolling back to pbxnsip.. grr (which works)
