"Boomerang" caller timeout! Where is this setting at now?
Discussion in '3CX Phone System - General' started by dx7, Dec 3, 2010.
  1. dx7
    dx7
    Oct 7, 2010
    25
    Well, I'm aware this setting is not called boomerang anymore but a timeout setting is really needed. I've learn through an outdated post that there was such a setting where you could specify timeout in seconds for the PBX fetching. I am getting an answering machine on a cell phone and the prompt repeatedly asks the callee to press 1 for taking the call or pound to send to voice mail. Since the answering machine can't interact, the answering machine allows the PBS to repeatedly record the prompt over and over, until the PBX decides to timeout.
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,475
    94
    Re: "Boomerang" caller timeout! Where is this setting at now
    This option is now called Rebound.
    It can be found in your extension's forwarding settings.
  3. dx7
    dx7
    Oct 7, 2010
    25
    Thanks Leonidas,
    You are right, it is called rebound, but you can't configure how to make it timeout. You were able to do that with boomerang. As it is now rebound it will ask FOREVER to accept or to send a call to voice mail. Answering machines on a cell phone will take the call and then you have a very unintended thing: A machine talks to another machine endlessly until the answering machine on the cell phone times out and hangs up or until the maximum allowance time of rebound/boomerang times out.
    If rebound tells that the phone was picked up it should only repeat TWICE the prompt (this should be programmable).
  4. dx7
    dx7
    Oct 7, 2010
    25
    REBOUND: Searched the string. NOT IN THE MANUAL
    And neither "rebound" nor "boomerang" are strings that can be searched in the manual.
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Try to open "custom parameters" page and type "BM" in the "filter" field...
  6. dx7
    dx7
    Oct 7, 2010
    25
    Thanks SY!
    There it was! I wonder if anyone knows the reason why this is not in the manual.
    If you knew where to find that I wonder if you know the answer to a very similar type of issue: http://www.3cx.com/forums/skype-gateway-imports-provisioning-settiings-can-t-export-18115.html
    Is there such a thing as documentation on the Custom parameters that can be downloaded?
    Is there full documentation on the 3CX Skype gateway available anywhere?
    3CX is pretty amazing, I feel like I was given a treasure but that I had to find it in a labyrinth.
  7. SY
    3CX Support
    Jan 26, 2007
    1,825
    All information is on http://www.3cx.com/blog/
