Borderless SIP supported in 3cx
Discussion in '3CX Phone System - General' started by Jay, Aug 24, 2017.
  1. Jay
    Jay
    Aug 24, 2017
    5
    Hi All,
    I've been searching around whether 3cx supported Borderless SIP provider but unable to get any finding. I know this means that it is not supported but is there anyway I can configure Borderless SIP in 3cx? Have anyone done it before?
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    228
    17
    Hello @Jay,
    Please do note that supported VoIP providers are providers that have been tested for their functionality with PBX and succeeded. If you want to use a non supported provider,you can do so by selecting the "Generic" under "Select Country" and "Select Provider in your Country" fields in SIP Trunks>>Add SIP Trunk.
    Thank you
  3. Jay
    Jay
    Aug 24, 2017
    5
    Hi loannisM_3CX,
    I have tried configuring it with generic sip trunk and it cant seems to register.
  4. IoannisM_3CX
    Aug 10, 2017
    228
    17
    Hello @Jay,
    What is the error you get?
  5. Jay
    Jay
    Aug 24, 2017
    5
    No error shown, below is the screenshot
  6. IoannisM_3CX
    Aug 10, 2017
    228
    17
    Hello @Jay,
    The specific screenshot you provided is of the SIP Trunk configuration, please do not that errors are shown in the Event log on Dashboard. Try re-register and then go to the Event log and check if there's an entry for this action.
  7. Jay
    Jay
    Aug 24, 2017
    5
  8. IoannisM_3CX
    Aug 10, 2017
    228
    17
    Hello @Jay,
    Thank you for the screenshot but i can't see what the error is. I need to see the entire entry in the Event log, the valuable part for troubleshooting is the error explanation. Please do provide me with this information but make sure that you hide sensitive information.
    Thank you
  9. Jay
    Jay
    Aug 24, 2017
    5
    below is the more detailed screenshot
    I am able to ping the sip server
  10. IoannisM_3CX
    Aug 10, 2017
    228
    17
    Hello @Jay,
    Thank you for the screenshot. In order to make sure that you reach your SIP provider you have to do an nslookup.
    In the first screenshot you use an FQDN: sip.borderlesshub.co (which i can personaly reach) and on the second screenshot you use an FQDN: siptrunk.bordelesshub.co which i cannot personaly reach.
    Please do contact your sip provider first in order to give you the right settings.
    Thank you
    #10 IoannisM_3CX, Aug 25, 2017
