BPA430 working with 3CX
Discussion in '3CX Phone System - General' started by thereverend, Sep 17, 2011.
  1. thereverend
    thereverend New Member
    May 29, 2011
    100
    Can someone please tell me how to access the BPA-430 and change the settings to work with 3CX.. Also what is the IP address of the unit ?O hope someone can help. Thanks
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    803
    45
    Reading from this site http://www.8x8.com/Support/installationinstructions.aspx#b430
    You have to download the executable to detect the IP-address of the BPA430
    http://www.8x8.com/Support/BusinessSupport/Downloads.aspx
    Good luck.
  3. thereverend
    May 29, 2011
    100
    Ok, but can this be configured to work with 3cx?
  4. thereverend
    May 29, 2011
    100
    ++Ok I got the IP address on the ADAPTOR and was able to log onto it but the only thing it asks for is the NTP server info, Would this be the 3cx server ip address?
    [​IMG]
  5. leejor
    10,861
    302
    The NTP server is a time server (sets the internal clock). If you do a search on the NET, you'll find quite a number that you can use.
  6. thereverend
    May 29, 2011
    100
    How do i get to the SIP server config on this BPA-430 unit?
  7. complex1
    Jan 25, 2010
    803
    45
    Scroll down the tabs in the BPA-430 unit and look for SIP settings?
    For example: Administration tab, Home tab, LAN tab, and so one.....
  8. thereverend
    May 29, 2011
    100
    It is not showing these tabs anywhere.. Do you know what the URL would be for example for sip settings 192.168.1.110/admin
    something like that.. The tabs do not seem to be showing
  9. thereverend
    May 29, 2011
    100
    Here is what I get from the screen..
    [​IMG]
    Where do i find a BOOT LOADER for this and a FIRMWARE that will work.. ? :?:
  10. complex1
    Jan 25, 2010
    803
    45
    Have you searched the internet?
    If you can’t find any SIP settings in this unit, maybe this device don’t support SIP?
    Please keep in mind; this phone device is not supported by 3CX.
  11. thereverend
    May 29, 2011
    100
    The unit is a SIP unit. Just looking on how to get into the settings to change the SIP settings.
  12. leejor
    10,861
    302
    Where did you acquire the device, where was it used previously? Is there a possibility that it is locked to a specific provider? On most unlocked devices it is usually obvious how to get into changing settings. On the majority of locked devices these will be either hidden, or will ask for an admin password.
  13. thereverend
    May 29, 2011
    100
    I bought it from EBAY and it looks as it it was used at one time with PACKET8 , They are a SIP provider. Just looking to configure it for 3CX.. So i can hook up my fax. Any help is great.
  14. syntheticexctasy
    Dec 23, 2011
    I'd love to be able to get these little guys working as well. I have tried several different firmware flashes on the device, and it won't take any. I have the same app and downloader code as the original OP. Interestingly enough, there is a 40 pin header on the device, which I am assuming is some kind of JTAG or serial connection.
