Solved Brand new install, no incoming?
Discussion in '3CX Phone System - General' started by Bob Henderson, Mar 31, 2017.
  1. Bob Henderson
    Mar 15, 2017
    6
    Brand new install, with Badwidth.com as my sip trunk. Just got the provisoning into like 2 hours ago. All calls to the number however go right to a busy signal.
    Firewall test is golden. Inbound route is supposed to go to an IVR for the DID, which is setup. Anything else I can check? outgoing works fine.
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    first test would be to turn on wireshark on the 3cx server and see if you see SIP traffic coming in when you call that number. If you do, then its related to 3cx setup. If you dont theres something wrong on the provider end.
  3. Bob Henderson
    Mar 15, 2017
    6
    Doing that now.
    I do have a ticket open with the provider, and they're telling me they are getting a '407 error' back from us on the calls. I'm brand new to SIP, does that make sense?
  4. leejor
    11,113
    329
    Check the 3CX Activity log to see if there is an entry for the incoming call, and any error message associated with it. It may be an internal destination (routing) problem.
    #4 leejor, Mar 31, 2017
  5. Bob Henderson
    Mar 15, 2017
    6
    Thanks to the help of jason up there, we're up and going. Was a combo of things, but they're resolved now!
  6. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    yay ! :)
    Always happy to help ...
