Breakout of users' voice mail box
Discussion in '3CX Phone System - General' started by telis, Jan 6, 2010.
  1. telis
    telis New Member
    Aug 13, 2007
    148
    21
    I have seen a feature on some PBX systems where it is possible to break out of a users voice mail.
    Here are a couple of scenarios, there are plenty more I can think of.
    Scenario One
    An external call comes in to the digital receptionist. The caller press option 4, the option to connect the Steve. However Steve's on the phone so the caller get's Steve's voicemail.
    "Hi, you're through to Steve's voicemail I'm unavailable at the moment. Please 0 to try someone else, or please hold to leave me a voice mail message."
    The call is quite urgent, and the caller thinks Helen can help instead, so the caller presses 0, this goes to the breakout destination configured for Steve, which in this case is the IVR, and then the caller chooses option 5 for Helen who answers the call.
    Scenario Two
    An external call comes in to the direct line of John in Sales. John is on the road and in meetings all day so the call goes to John voice mail after a few rings. The sales department are pretty hot on everyone changing their VM message every day...
    "Hi, this is John's voicemail, it's 06/01/09 and I'm out of the office and in meetings all day today. Please press 0 to go to sales reception, or hold to leave me a message."
    The caller needs to speak to someone in sales ASAP, so she presses 0 and the call goes through to the sales receptionist and get's picked up straight away.
    Is this possible in 3CX? If so how, if not are there any workarounds....
    ChrisE
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    You can specify "forwarding" rules for each extension...
  3. comresource
    comresource Member
    May 22, 2009
    303
    You can press "*" to be sent to the Operators extension If that is what you mean. Of course if you create your own greeting message you will need to let the caller know this.
  4. telis
    telis New Member
    Aug 13, 2007
    148
    21
    @Stephan - Thanks for the reply, however I can't see how forwarding helps in scenarios specified.
    @Danny
    Thanks, I have now found this feature!
    It seems the "operator extension" is set system wide and is defined in the Settings -> General section. The extension has to be real extension and can't be a Digital Receptionist, but you can create a dummy extension with a forward rule to a digital receptionist or hunt group etc. I now have this tested and working. It's a shame the extension can't be overridden on a per-user basis (as on the IP Office), but it's welcome nonetheless.
    Cheers Danny.
    ChrisE,
    Telis.
