Bria 3 for Windows, SRTP/TLS
Discussion in '3CX Phone System - General' started by helvetic, Oct 27, 2011.
  1. helvetic
    Oct 27, 2011
    Hello
    I have enabled STRP/TLS on 3cx and everyting working great except for inbound calls on Bria 3 for Windows.
    Incoming call are rejected immediately and show up as unanswered calls in the call log, outbound encrypted call work without any problems.
    I sent the log files to counterpath support and they told me i have to ensure the incoming call does not contain an insecure option and the call should go through as expected. I see there is no such option in 3cx, i only found the option to enable SRTP per extension but not to force it.
    Any help is much appreciated.
    Thank you.
