Bria Softphone
Discussion in '3CX Phone System - General' started by athanasios, Jul 31, 2008.
  1. athanasios
    Jul 31, 2008
    11
    I use 3CX free version 6.0 and I use “Bria” softphone. I’ll like to direct all my outgoing numbers to a deskphone “Elmeg IP-290” in order to use handset instead of headset.
    Please guide me if that’s possible.
    Thank you.
  2. Anonymous
    Anonymous Guest
    Can you please clarify? "Direct my outgoing numbers"?
  3. athanasios
    Jul 31, 2008
    11
    Thank you for your reply.
    I need to format the number from the softphone and speak from the deskphone.
  4. Anonymous
    Anonymous Guest
    Then simply switch the VoIP client to deskphone mode.
    When you dial a number in the softphone, your hard phone will ring and you will be connected to the caller.
    Thanks,
  5. athanasios
    Jul 31, 2008
    11
    Thank you but this is not my case.
    I use "Bria softphone" and I have not this possibility. Meantime the "Elmeg IP-290" is not a USB phone is a 'lan' phone.
    Thank you again, any other solution please?
  6. Henk
    Henk Member
    Nov 13, 2007
    250
    Set up a call group, including both phones (the soft and the hard phone) you than can make the decision which one to pickup when the call comes in.
    H.
  7. athanasios
    Jul 31, 2008
    11
    Thank you Henk, but I need to format the number from the softphone and speak from the deskphone.
    Your suggestion is for pickup when the call comes in.
    How I can format the number from the softphone (Bria) and and speak from deskphone (Elmeg IP-290) this is my problem.
    Thank you again for your help.
  8. jspearso
    Aug 16, 2008
    8
    i tried to do the same thing you cant you have to use the Free voip client phone
