Bridge and Remote Presence
Discussion in '3CX Phone System - General' started by GabrielVE, Feb 16, 2017.
  1. GabrielVE
    Oct 25, 2016
    31
    Hi all!
    Need a few suggestions on what else to try so as to see the Remote Presence of the 2 connections that I was able to connect via 3CX bridge feature
    The call feature works fine, I can dial in the other extensions and can hear the calls fine, vice versa
    But the Presence doesn't seem to show up
    Recommendation is to ensure that FQDN and Port are set, and I think they are
    FQDN:5001 (where as 5001 is the https port used)
    I can access the 3CX Management Console if I go to https://fqdn:5001 - so I assume that both FQDNs and port are correct..
    Would appreciate any inputs and recommendation!
    Thanks in Advance!
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @GabrielVE
    Which versions of the PBX are you running and what type of license do you have? Are both sides the same version?
  3. GabrielVE
    Oct 25, 2016
    31
    Hi Yiannis,
    Both servers have Pro license, and running V15 SP4
    Thanks,
  4. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    Send me a welcome email let us check for you.
    If you dont see the presence, then we should not see this either.
    Send me details in PM.
  5. GabrielVE
    Oct 25, 2016
    31
    Hi @YiannisH_3CX / Nick,
    Just wanted to revive this thread and update you on things!
    We were able to get one of the Presence working... It's like PBX1 can't still see the Remote Presence of PBX2 but PBX2 can see the Presence of PBX1
    Both PBX can call each other still
    So wondering what else we need to check..
    Firewall Test returned OK for both PBX
    Thanks!
  6. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    Check licenses on both pbx. Some license keys can send and receive information but others can send only.
  7. GabrielVE
    Oct 25, 2016
    31
    Hi Nick
    Thanks for responding! Both versions are on 3CX Pro as required by the Remote Presence to work
    Regards,
    Gabe
  8. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    then check the firewall ports for https on both because if you have a b ridge connection with presence, then it should work
  9. GabrielVE
    Oct 25, 2016
    31
    Hi Nick,
    Thanks for responding again, we run the Firewall Test on both 3CX PBX 1 and 2 and were showing fine, the https port (5001) which we used was also fine as we can access the 3CX management console using https://fqdn:5001 on both machines
    This has been really odd.. :(
    Thanks,
  10. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    check dns, resolutions change fqdn of pbx to ip - they depend on these things
