Bridge Caller ID
Discussion in '3CX Phone System - General' started by craigreilly, Jan 8, 2015.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,977
    183
    Bridge calls are working ok between 2 sites.
    The Main site is 4 digit extensions
    Remote site is 3 digit extensions
    The remote site extensions are 920-960 (Same extensions from legacy system. Not sure I am thrilled with the 911 emergency code in the same range though.)
    The internal site id is 109.
    So, the dialing rule is dial "109" then last 2 of extension. so 10920
    The rule strips the 10 and dials over the bridge.
    Works great.
    So - on to the issue. On an iPhone and Yealink (not sure about Android. But 3cx Phone for Windows is ok):
    Now when I call the main site from remote side, it has only the 3 digit extension. So, I go into the bridge setup at Main site and add "Outbound Rule Prefix" of 10. This way, it should show 10920. Instead it shows 0920. So, instead I add 110 as the outbound rule prefix and it shows correctly. If I change these to a 5 or 55 then both digits show.
    Any idea why the first digit is now showing when set to 10?
    10,371
    230
    Did you investigate as to where the "1" is being stripped? If it is being sent in the SIP message, then obviously the destination PBX is stripping it. Might narrow what to look for. Was there any CID manipulation set-up for other "outside" calls?
    And that extension range choice (9XX), was...unfortunate, to say the least.
  3. craigreilly
    Feb 1, 2012
    2,977
    183
    Kicking myself for not changing the 900 range of extensions. Not awful. Not an industrial plant where we work with chemicals. :) Our corporate office used to be 9xx as well before I went to 3cx and changed to 4 digit extensions. But they had to dial 9 to get an outside line to call 911 on the legacy system.
    So, onto the issue:
    The CID for iPhone: 0920
    The CID for Yealink: 0920
    The CID on 3cxPhone for Windows: 10920
    I changed my outbound rule to strip 0 - just to ensure that it wasn't matching the bridge outbound rule on incoming calls... not something I expected, but wanted to test.
    Looking at 3cx log, notice the top entry from the call shows 10900 and the second entry shows 0900.
    Even stranger: The 3cx Phone on incoming call shows 0900 and the Recent Call shows 10900.
  4. leejor
    10,371
    230
    I have to assume that this, is not in regards to a call that is using a Bridge trunk??
  5. craigreilly
    Feb 1, 2012
    2,977
    183
    Yes that is the call. 900 is the remote receptionist.
    The main office bridge setup says dial 10 to reach them.
  6. leejor
    10,371
    230
    Are there rules set up to manipulate caller ID (strip digits) on any inbound calls?
    Does the calling extension have a number set in the number to be displayed field?
    Have you used Wireshark to compare calls?
  7. craigreilly
    Feb 1, 2012
    2,977
    183
    I do not know how to manipulate inbound caller id on the bridge, except the PREFIX field.
    No outbound caller id is set. The extension # is what is showing on the MAIN office side when a call comes in.
    If I leave the PREFIX field blank on the Bridge for incoming side - All I see is the extension. This is not good for MISSED CALLS when I want to look at history and redial.
    Compare calls? There is 1 call. The call from Remote to Local.
    Just different result where I view it. All 3 devices are live at the same time: 3cx Phone for Windows, Deskphone and iPhone.
    I am out of office today. Plan to do some more research on Monday.
  8. craigreilly
    Feb 1, 2012
    2,977
    183
    Tried with another bridged system. The logs below could be a bit confusing as the Grand-stream was used to place the call on the Remote PBX (configured remotely), as well as one of the registered endpoints on the MAIN 3cx system.
    The Bridge Virtual Ext # is 10155
    Bridge is set to prefix 1155.
    My outbound rule is set for 155 prefix (doesn't appear to matter as we strip 3)
    I want the phones to show 155+ext in the incoming call and the history.
    The call coming into the PBX
    Code:
    13-Jan-2015 16:25:09.892	[Flow] Call(C:27221): making call from L:27221.1[Line:10155<<+115544] to T:Extn:4954@[Dev:sip:4954@10.0.1.102:49682,Dev:sip:4954@10.0.1.102:22632,Dev:sip:4954@10.0.3.65:5062,Dev:sip:4954@10.0.1.24:5077;ob;inst="684864",Dev:sip:4954@10.0.1.102:43433,Dev:sip:4954@10.0.1.102:24986,Dev:sip:4954@127.0.0.1:5488;rinstance=90812a9110e4b72e]
    13-Jan-2015 16:25:09.892	[CM503027]: Call(C:27221): From: Line:10155<<+115544 ("Craig Test" <sip:115544@mysipdomain.local:5060>)  to  T:Extn:4954@[Dev:sip:4954@10.0.1.102:49682,Dev:sip:4954@10.0.1.102:22632,Dev:sip:4954@10.0.3.65:5062,Dev:sip:4954@10.0.1.24:5077;ob;inst="684864",Dev:sip:4954@10.0.1.102:43433,Dev:sip:4954@10.0.1.102:24986,Dev:sip:4954@127.0.0.1:5488;rinstance=90812a9110e4b72e]
    13-Jan-2015 16:25:09.891	[CM503004]: Call(C:27221): Route 1: from L:27221.1[Line:10155<<+115544] to T:Extn:4954@[Dev:sip:4954@10.0.1.102:49682,Dev:sip:4954@10.0.1.102:22632,Dev:sip:4954@10.0.3.65:5062,Dev:sip:4954@10.0.1.24:5077;ob;inst="684864",Dev:sip:4954@10.0.1.102:43433,Dev:sip:4954@10.0.1.102:24986,Dev:sip:4954@127.0.0.1:5488;rinstance=90812a9110e4b72e]
    Yealink shows 15544. (1 digit stripped)
    Code:
    13-Jan-2015 16:25:09.934	Route to L:27221.4[Extn] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=fa26a03ca5540c10 Call-ID=MThlYzBiODllYTYwODcwYzJhYWU3ZTgzZmEwYzQxOWM.:
    			INVITE sip:4954@10.0.3.65:5062 SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-fa26a03ca5540c10-1---d8754z-;rport
    			Max-Forwards: 70
    			Contact: <sip:15544@10.0.0.12:5060>
    			To: <sip:4954@10.0.0.12>
    			From: "Craig Test"<sip:15544@10.0.0.12:5060;nf=b>;tag=0275bc35
    			Call-ID: MThlYzBiODllYTYwODcwYzJhYWU3ZTgzZmEwYzQxOWM.
    			CSeq: 1 INVITE
    			Alert-Info: <http://www.notused.invalidtld>;info=national
    			Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    			Content-Type: application/sdp
    			Supported: replaces
    			Content-Length: 397
    			v=0
    			o=3cxPS 89170903040 134335168513 IN IP4 10.0.0.12
    			s=3cxPS Audio call
    			c=IN IP4 10.0.0.12
    			t=0 0
    			m=audio 7170 RTP/AVP 0 8 3 13 9 18 110 99 101
    			a=rtpmap:0 PCMU/8000
    			a=rtpmap:8 PCMA/8000
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    			a=rtpmap:9 G722/8000
    			a=rtpmap:18 G729/8000
    			a=fmtp:18 annexb=no
    			a=rtpmap:110 iLBC/8000
    			a=rtpmap:99 SPEEX/8000
    			a=rtpmap:101 telephone-event/8000
    			a=sendrecv
    Grand-stream shows 15544. (1 digit stripped)
    Code:
    13-Jan-2015 16:25:09.927	Route to L:27221.2[Extn] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=a749d333f26df014 Call-ID=ZGVmZDA0YjVlMDA4ODJjNjAxMTQyNWY5ODZiOWQzMGI.:
    			INVITE sip:4954@10.0.1.102:49682 SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-a749d333f26df014-1---d8754z-;rport
    			Max-Forwards: 70
    			From: "Craig Test"<sip:15544@10.0.0.12:5060;nf=b>;tag=22167530
    			Call-ID: ZGVmZDA0YjVlMDA4ODJjNjAxMTQyNWY5ODZiOWQzMGI.
    			CSeq: 1 INVITE
    			Supported: replaces
    			Content-Length: 397
    			v=0
    			o=3cxPS 88348819456 125913006081 IN IP4 10.0.0.12
    			s=3cxPS Audio call
    			c=IN IP4 10.0.0.12
    			t=0 0
    			m=audio 7166 RTP/AVP 0 8 3 13 9 18 110 99 101
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    			a=fmtp:18 annexb=no
    			a=sendrecv
    3cx Phone for Windows showed 115544. This reflects bridge setup properly. Can not find the lines in the logs. Maybe because it is the IP of the server and not the desktop.
    iPhone showed 115544 is history but 15544 in the incoming call.
    Code:
    13-Jan-2015 16:25:09.938	Route to L:27221.5[Extn] sends Invite-OUT Send Req INVITE from 0.0.0.0:0 tid=546dba3cf73fa869 Call-ID=MzZmNTIxM2YxMjMzY2QxZmIxZDliNWVkZDE2NWQxYjk.:
    			INVITE sip:4954@10.0.1.24:5077;ob;inst="684864" SIP/2.0
    			Via: SIP/2.0/ ;branch=z9hG4bK-d8754z-546dba3cf73fa869-1---d8754z-;rport
    			Max-Forwards: 70
    			To: <sip:4954@10.0.0.12:5060>
    			From: "Craig Test"<sip:15544@10.0.0.12:5060;nf=b>;tag=321fab3c
    			Call-ID: MzZmNTIxM2YxMjMzY2QxZmIxZDliNWVkZDE2NWQxYjk.
    			CSeq: 1 INVITE
    			Supported: replaces
    			Content-Length: 397
    			v=0
    			s=3cxPS Audio call
    			c=IN IP4 10.0.0.12
    			t=0 0
    			m=audio 7172 RTP/AVP 0 8 3 13 9 18 110 99 101
    			a=rtpmap:3 GSM/8000
    			a=rtpmap:13 CN/8000
    			a=fmtp:18 annexb=no
    			a=sendrecv
  9. leejor
    10,371
    230
    So all three sets have the same extension number. and all three logs show the same info.
    The difference being that the Windows phone shows the CID with the extra 1 prefix and that same 6 digit number shows in the iPhone history? Only the iPhone history?
    I may be way off base, but wondered about the plus sign in the first log. I don't recall seeing something like that before.
  10. craigreilly
    Feb 1, 2012
    2,977
    183
    I sure wish someone at 3cx might just chime in... I do not have a support contract.
    +1 - like national dialing code... so, lets strip it.... but i don't have anything setup there.
    I tried in the other direction - Corp to Field office:
    Code:
    14-Jan-2015 13:42:26.591   [Flow] Call(C:3090): making call from L:3090.1[Line:10155<<[color=#FF00FF]+1[/color]14954] to T:Extn:44@[Dev:sip:44@10.0.1.102:43729]
    14-Jan-2015 13:42:26.591   [CM503027]: Call(C:3090): From: Line:10155<<+114954 ("Craig Reilly" <sip:114954@mysipdomain.local:5060>)  to  T:Extn:44@[Dev:sip:44@10.0.1.102:43729]
    14-Jan-2015 13:42:26.591   [CM503004]: Call(C:3090): Route 1: from L:3090.1[Line:10155<<[color=#FF00BF]+1[/color]14954] to T:Extn:44@[Dev:sip:44@10.0.1.102:43729]
    14-Jan-2015 13:42:26.590   [Flow] Call(C:3090): has built target endpoint: Extn:44 for call from L:3090.1[Line:10155<<+114954]
    Same result.
    I just tried another combination of numbers - like 22. Both stayed. It seems when it starts with a "1" is when it happens.
    On my test system, I changed the country code in custom to "0".
    The caller id then presented correctly.
    According to this link it works as programmed. But perhaps, should not be applied to bridge calls.
    http://www.3cx.com/blog/voip-howto/caller-id-processing-distinctive-ringing-alert-info/
      File size:
      12.3 KB
      799
  11. craigreilly
    Feb 1, 2012
    2,977
    183
    Anyone with a valid support contract willing to ask 3cx about this behavior?
  12. jasit
    jasit New Member
    Feb 12, 2013
    169
    Craig,
    I don't understand why you are adding prefix numbers to your extensions. I have 2 locations, Manitoba is 22xx and Ontario is 330 - 390 and the interoffice dialing is just the four or three digit extension number
    So in Manitoba my outbound rule for the Ontario is Calls to numbers starting with prefix 3 with a length of 3 and strip digits 0
    In Manitoba 311 is a information number so I have a rule for that above the rule for the Ontario office.
  13. craigreilly
    Feb 1, 2012
    2,977
    183
    CORP OFFICE is 4 digits.
    FIELD OFFICES are each 3 digits.
    To know which field office you are calling, you dial the OFFICE ID followed by the users extension.
    When one of the field offices calls the corporate office, it displays only their extension, thus the need to add the PREFIX in the Bridge setup.
    The issue comes into play that my field offices start with the number 1 or the number 2.
    So the offices that start with 1 (ie 109 or 155) for the prefix are getting stripped.
    We have overcome this by changing the Country selection to <null> but it would seem this is a bug in the design.
    I think for you only 1 field office - you setup a rule to just dial 3 digits. With multiple field offices, I do not have that luxury.
