Bridge calls Busy
Discussion in '3CX Phone System - General' started by boba1120, Jun 22, 2012.
  1. boba1120
    May 9, 2012
    14
    Hi all, new issue here with a bridge setup. I have a Master at our main office, and smaller Slave installation at branch. Registration is successful using internal IPs over our Watchguard VPN tunnel. However, any calls to extensions at remote location come up busy. The outbound rule is catching and stripping appropriately.
    Here's the Slave log:
    Code:
    13:02:45.366|.\CallLeg.cpp(143)|Log5||CallLeg::onNewCall:[CM500002]: Info on incoming INVITE:
    INVITE sip:7114@192.168.30.100:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.30.207:5060;branch=z9hG4bK-e09983ae
    Max-Forwards: 70
    Contact: "Karen Brown"<sip:107@192.168.30.207:5060>
    To: <sip:7114@192.168.30.100>
    From: "Karen Brown"<sip:107@192.168.30.100>;tag=7ecc096e67815fb6o0
    Call-ID: ad9635ce-d5b61ed6@192.168.30.207
    CSeq: 102 INVITE
    Expires: 240
    Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE
    Proxy-Authorization: Digest username="107",realm="3CXPhoneSystem",nonce="414d535c05f5363502:9d4e97b221da3a9ed6b16a6242d485b5",uri="sip:7114@192.168.30.100:5060",algorithm=MD5,response="ededfb811e50d2dc445895b1a298ebcd"
    Supported: replaces
    User-Agent: Cisco/SPA504G-7.5.1a
    Content-Length: 0
    <br>
    13:02:45.375|.\CallCtrl.cpp(346)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(658): Incoming call from Ext.107 to <sip:7114@192.168.30.100><br>
    13:02:45.376|.\Extension.cpp(1407)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.107: Device info: Device Identified: [Man: Cisco;Mod: SPA Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco/SPA504G-7.5.1a] PBX contact: [sip:107@192.168.30.100:5060]<br>
    13:02:45.376|.\CallLeg.cpp(1194)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:658.1<br>
    13:02:45.377|.\SLServer.cpp(861)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210000] C:658.1:Offer received. RTP connection: 192.168.30.207:16458(16459)<br>
    13:02:45.377|.\CallCtrl.cpp(529)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:7114@192.168.30.100><br>
    13:02:45.378|.\CallCtrl.cpp(708)|Log2||CallCtrl::onSelectRouteReq:[CM503004]: Call(658): Route 1: PBXline:114@(Ln.10003@Maserati to Porsche)@[Dev:sip:10003@172.30.6.240:5060]<br>
    13:02:45.424|.\SLServer.cpp(861)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210006] C:658.2:Offer provided. Connection(by pass mode): 192.168.30.207:16458(16459)<br>
    13:02:45.431|.\Target.cpp(441)|Log2||Target::makeOneInvite:[CM503025]: Call(658): Calling PBXline:114@(Ln.10003@Maserati to Porsche)@[Dev:sip:10003@172.30.6.240:5060]<br>
    13:02:45.868|.\CallLeg.cpp(326)|Log2||CallLeg::onFailure:[CM503003]: Call(658): Call to sip:114@172.30.6.240:5060 has failed; Cause: 486 Busy Here; warning: Disabled by Forwarding Rule; from IP:172.30.6.240:5060<br>
    13:02:45.869|.\Call.cpp(1091)|Log2||Call::RouteFailed:[CM503016]: Call(658): Attempt to reach <sip:7114@192.168.30.100> failed. Reason: Busy<br>
    13:02:45.870|.\Call.cpp(605)|Log2||Call::DoEndCall:[CM503020]: Normal call termination. Reason: Busy<br>
    And here's the Master:
    Code:
    13:02:52.692|.\Line.cpp(357)|Log2||LineCfg::getInboundTarget:[CM503012]: Inbound office hours rule (unnamed) for 10003 forwards to DN:101<br>
    13:02:52.703|.\CallCtrl.cpp(346)|Log2||CallCtrl::onIncomingCall:[CM503001]: Call(66485): Incoming call from 10003@(Ln.10003@Porsche to Maserati) to <sip:114@172.30.6.240:5060;user=endcall><br>
    13:02:52.705|.\Line.cpp(1460)|Log2||Line::printEndpointInfo:[CM505004]: Bridge:[Porsche to Maserati] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhoneSystem 10.0.23053.0] PBX contact: [sip:10003@172.30.6.240:5060]<br>
    13:02:52.708|.\CallCtrl.cpp(529)|Log3||CallCtrl::onSelectRouteReq:[CM503010]: Making route(s) to <sip:114@172.30.6.240:5060;user=endcall><br>
    13:02:52.708|.\Call.cpp(1091)|Log2||Call::RouteFailed:[CM503016]: Call(66485): Attempt to reach <sip:114@172.30.6.240:5060;user=endcall> failed. Reason: Busy<br>
    13:02:52.708|.\Call.cpp(605)|Log2||Call::DoEndCall:[CM503020]: Normal call termination. Reason: Disabled by Forwarding Rule<br>
    I don't know Wireshark that well, but I took a look and it doesn't look like any traffic is heading out to the target extension's IP. Something in the server doesn't seem to want to route the call maybe?
    10,861
    301
    Does 114 have a call forwarding rule that cannot be utilized by the call?
  3. boba1120
    May 9, 2012
    14
    I don't see how, it has a pretty simple "send to mobile" or "send to voicemail". Also this happens with any extension I try.
  4. boba1120
    May 9, 2012
    14
    I should point out, it seems to happen in both directions as well.
  5. boba1120
    May 9, 2012
    14
    UPDATE: Partial workaround, but definitely some odd behavior.
    On a whim I adjusted the bridge setting for what to do with a call if the target extension doesn't exist. Originally I had it set to "endcall", which I believe is the default. Interestingly, the text "user=endcall" shows up in the original log. I set it to forward to the reception extension instead, and suddenly bridge calls were able to go through no problem. But in both cases, the target extension definitely existed, and was not busy. Or does "destination" in the text for this setting refer to the server on the other end? Either way, it should never have been invoked, so why does the behavior change?
  6. leejor
    10,861
    301
    So...if you have the call go to an extension, in the other PBX that has no forwarding set-up at all, does it ring through properly?
  7. boba1120
    May 9, 2012
    14
    Well, the setting in question is on the target server's bridge configuration, in other words the server receiving the call. The text for the setting is:
    Basically it seems that if this is set to End Call then the call always fails, but if it is set to anything else the call does ring through properly. It just doesn't make sense, unless I'm completely misinterpreting what this setting is supposed to do. It would seem that if the "destination targeted" is valid then the call should always go through, and the End Call behavior should not come into play.
