Bridge CID
Discussion in '3CX Phone System - General' started by TSlocum, Oct 16, 2015.
  1. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    14
    We have some bridges between our office branches. Each branch uses 4 digit extensions. Between some branches, the caller ID removes the first digit. So when 1051 at office A calls, office B sees 051 on their caller ID. It doesn't happen with all branches. What could be causing this?
    If it matters, we have outbound rules set up so users don't have to dial anything extra to use the bridge. They can just dial the 4 digit extension at any branch to reach the user.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,129
    207
    I had to play with Settings/ Advanced and I think changed the Country to something <select> as the Bridge was stripping the "1" as it thought it was part of a dialing code. It doesn't seem to happen if the extension starts with a 2 thru 9 (atleast in the USA).
    Perhaps I did this under custom Parameters. Not remembering the particulars as its not part of my current setup.
  3. Mich
    Jan 16, 2013
    We are having this issue as well with the extensions starting with a 1 - If I change the country to Null in the Parameters area.. does that affect the e164 format and the calling line ID showing up on the far end when calling overseas ? We are in North America (1) country code as well. I can manipulate the bridge to show the 1 but if they leave a voicemail it shows up as on 3 digits and strips the 1. Would hate to have to recreate the entire system as it's quite a large PBX just to overcome this issue. We are bridging between multiple offices and other office that have their extensions starting with any number between 2-8 ( 9 is used for out-dialing) do not have this issue.
    Just concerned that removing the country and setting it to Null will affect the overseas CLID display of the number.
    any ideas?
    systems are v14
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,486
    357
    I would not change the the country to Null in the parameters. this will affect the e164 settings.
    Revise your bridge outbound rules in case you have not added a outbound prefix in bridge settings but have strip 1 in the outbound rules.
  5. choimarc
    Feb 19, 2014
    72
    6
    I have the same problem. If I disable the e164 processing, the 1 comes up. If I disable it, it is stripped.
    Thanks.
