bridge connection
Discussion in '3CX Phone System - General' started by stash, Jan 24, 2013.
  1. stash
    stash New Member
    Feb 23, 2012
    213
    I have set bridge connection from Guam to Philippines. The US server acts as the master UDP bridge.
    the problem is. When someone called US server and wants to connect to Philippine extension it won't transfer the call. They can hear destination not available or extension not registered.
    But both system can talk to each other and the extension in Philippines is always registered.
    US uses extension 1xx and Philippines is 2xx.
    When i look into the activity log of Guam server i cannot see any problem.
    Outbound rule has no prefix, digit length is 3, call route to bridge strip digits 0.
    Thanks,
    STASH
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Post log, also try and setup PBX DELIVERS AUDIO in the bridge setup, make sure you have the boxes for sending and receiving calls set.
  3. stash
    stash New Member
    Feb 23, 2012
    213
    Sigma,
    OK i will update you later.
    Thanks,
    STASH
  4. stash
    stash New Member
    Feb 23, 2012
    213
    Hi Sigma,
    PBX delivers audio did not work.
    I did a work around for this.
    I created extension on US which are the extension of PI
    Create outbound rule for bridge which has prefix 8
    on the extension i create i edited forwarding rules send to external number prefix 8 + extension number which reside on the other side of the bridge.
    Thanks,
    STASH
