Bridge Limit
Discussion in '3CX Phone System - General' started by jendter, Jul 10, 2013.
  1. jendter
    Jul 10, 2013
    11
    Is there a limit to the number of bridges that can be configured in the Professional edition? We have 14 sites and I can see at least one site will have a bridge to each remote site.
    11,117
    329
    As I understand it, the only limitation is the number of conversations based on your licence. Extensions and trunks, (and I assume bridges, in that later category), have no limitations for practical purposes, at least none that I have seen reported. Your hardware specs will play a role in limiting size.
    Of course, with that many sites, you are going to have to plan out your numbering scheme and outbound rules to try to keep things (dialling) as simple as possible.
  3. jendter
    Jul 10, 2013
    11
    Thanks for the information. We are busy planning the dialing schemes. We are lucky in the fact that our call volume is quite low; usually around a max of 3 or 4 simultaneous calls per site.
