Bridge prefix mismatch
Discussion in '3CX Phone System - General' started by NetVu IT, Mar 27, 2017.
  1. NetVu IT
    Mar 16, 2017
    21
    I've a number of 3CX to 3CX bridges set up. One of these is set for an access code of 4 with most of the extensions on the other end starting with a 4; when someone dials one of these the 44 is being stripped, as it's being matched as +44, so only the last 2 digits of the extension appear as CLID. This only happens for the home country code. Other than changing the trunk access code, am I missing something obvious to stop this happening?
    Cheers.
  2. AlexDBarrett
    Jan 25, 2011
    71
    9
    Shooting from the hip as I do not have the full picture.
    My first thought is to change your numbering scheme.
  3. MRM
    MRM
    Dec 21, 2016
    53
