Bridge to Existing 3COM V3000
Discussion in '3CX Phone System - General' started by sjalife, Dec 21, 2015.
  1. sjalife
    Dec 21, 2015
    I am migrating away from a 3COM V3001 NBX system.
    The issue is that my current ISP does not support SIP trunks and I will not buy a Gateway since we are also migrating out of this ISP in less than a year so I need to use my current NBX as a gateway for, let's say: a year.
    I have searched the forums and cannot find the correct procedure for this.
    Specially since the 3COM side is completely undocumented.
    Can anyone help me?
  2. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    6
    Yikes!!
    This could be a tricky one.
    So just to be sure i understand this correct, on your V3000 are you using analog lines or a digital line card?
    Is your V3000 running in SIP mode?
    Do you know what software revision the V3000 is?
    So you want to keep the phone lines/T1 coming through the V3000 gateway, then from that feeding into the 3CX so you do not need to purchase a new gateway to work with 3CX?
    I used to be a certified tech and all on 3COM NBX/VCX and back in the say when we switches from our in house NBX to 3CX we did this for a while...
    Might be able to help you out with it.
  3. sjalife
    Dec 21, 2015
    Hey,
    Thanx for the help.
    So, yes, I have an R2 T1 PRI 32Ch Digital line.
    The PBX is running 6_5_22_b5.
    We do run it on SIP mode but you know that it was not fully implemented and with no support, so configuration is not straightforward.
    We run about 55 3Com phones and would be nice to keep those working and integrated for a while too (though no required).
    Attached you will find the main System Identity Screen and the SystemWide Settings Screen.
    So, how does the bridging work between these devices?
  4. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,243
    61
    Hey sjalife
    On the 3CX side, although it hasn't been tested by 3CX, you could try creating a SIP Trunk and then registering it with an equivalent entry on the 3COM side, then set up DIDs on the 3CX to route to where you want them to go.
    For the 3COM side, tsukraw might be able to help you more as he has worked with them before.
  5. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    HI this release NBX support SIP ( is old machine but for fine ), you need switch NBX on sip mode ( need upgrade memory ) .
    Trunk sip from NBX and 3CX work fine
    No problem call from 3CX to NBX and call out via ISDN , need correct manage dialplan on NBX but is more simple .
  6. sjalife
    Dec 21, 2015
    Hello Don
    My NBX is running SIP, please see above attachments and description.
    Now, on the 3COM, what configuration do I need to do in order to publish the trunk?
    I could not find the SIP Trunk settings.
  7. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    see snapshot
      File size:
      300.4 KB
      1,238
      File size:
      217.3 KB
      1,238
      File size:
      206.3 KB
      1,238
      File size:
      218.3 KB
      1,238
  8. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    6
    donbru01,
    Shoot me a PM with your email address.
    If you'd like ill give you a hand getting the trunks setup and the dialplan.
    Like i said back when we switched to 3CX from our V3000 we did the same thing for a period of time.
  9. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    tsukraw , I do not understand your last post?
    I not need help, I am trying to help sjalife in its request
    I have more hundred NBX V3000/V5000 connected on 3CX and i haven't problem
  10. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    6
    Sorry wrong person referenced
  11. sjalife
    Dec 21, 2015
    Hey Guys,
    Thank you all for your comments.
    I'm gonna try and follow tsukraw's recomendations and will post my results.
    Hopefully I get a chance in the next couple of days.
    Tsukraw, what adjustments need to be done on the dial plan on the 3COM?
    How do you go about the dial plan on the 3CX?
