GerhardKreuzer
- Joined
- Dec 23, 2009
- Messages
- 29
- Reaction score
- 1
I want to establish a bridge between to PBX, but no success after hours ..
Scenario:
Two private networks 192.168.xx were connectred via a VPN tunnel managed by routers. This works really fine and stable, I can access remote NAS boxes, computers and printers from both sides, even using computer explorer of windows. No problem.
The two PBX resides in different building /50km distance) and so they have a ISDN gateway each. This gateway also works fine, we can make calls outside and receive calls, we even can send and receive FAX, which was a big challenge.
Now I want establish a bridge, using my VPN tunnel to allow internal calls cross buildings without using the ISDN net.
Whatever I try, and I try really a lot, the bridge nerver goes green, for what reason ever.
So is there any hint?
Forgot everything about blocking ports, the VPN tunnel is totally transparent.
Thanks a lot for helping.
With best regards
Gerhard
Scenario:
With best regards
Gerhard
