- Joined
- Jun 14, 2010
- Messages
- 9
- Reaction score
- 1
We need to install 2 3CX systems in Bridged mode and the configuration and requirement is as below
Location A 3CX master with PRI
Location B 3CX slave with only extensions
When Caller from slave 3CX needs to make a call to the outside world, they would need to use the PRI in the master to acheive the same
When a outsider calls into a certain number in the PRI of the Master the calls have to be routed to the extensions in the Slave 3CX
Is it possible to configure it as above and how can we acheive the same
