Solved Bridged Offices Calls work one way?
Robin Haywood
We have a main office with 3CX standard hosted on our own server, on a VM. 60 odd users. We then have a remote office running 3CX pro, cloud hosted, to a SBC trunk onsite install to ease the setup.
The 2 sites are bridged and both ends show green. The Pro end can see presence of the main office and can call the users in the main office. The main office standard clients get the caller display of the remote calling in over the bridge. However if they try and return the call from history or just call it out right it just comes up with Not Found?
The user ext's in the main office are on extensions in range 1**. Remote are 2**. To avoid needing the extra digit to go over the bridge. Incase this was the issue I did try and use the extra digit setting but it made no difference.
The main office, due to it being on the local LAN, does not have the SBC trunk installed. I will probably try installing that on the VM the 3CX is hosted on next but I have a fear that might interfere with it....
Any ideas?
Thanks,
Robin
Not found potentially means that it can't find the destination and does not known how to route it. Do you have an outbound rule on the main office system for 2xx range of extensions to be routed over the bridge?
Checking the Activity Log as well, after you change the logging level to Medium or Verbose might also give you a few clues as to what may be causing this.
Nick thank you!! Pointed me in the right direction. I did have an outbound rule but it was last in the list. I moved it above the default line out and bingo!!! Fixed! I have played with so much firewall rules and ports with no luck!
Many Thanks for your very quick response and help! :)
Robin
You're very welcome! :)
Getting Started - Admin
gburcham
Get 3CX - Absolutely Free!
3CX
