Bridged sites in phone directory
Discussion in '3CX Phone System - General' started by jholcombe, Mar 21, 2016.
  1. jholcombe
    Jul 9, 2014
    79
    Does anyone know if it is possible to have extensions from bridged sites show up in the directory on the phones? We are using T46G handsets. Would that cause the destination extension name to show on the caller's phone?
    Thank you,
    --John
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    469
    77
    You can't unless someone manually combines the XML files for your different locations and then you point the phones to that combined file.
    However with the Yealink phones you can give phones access to the phone book for up to five locations.
    Manually this is setup by logging into the phones web interface and going to the directory tab and configuring "remote phone book". Simply take the values from a phone on site #2 and put them as the second phone book for site #1.
    This can also be configured at the template level so you don't have to manually configure the phones.
    if you want help with the templates let me know.
  3. jholcombe
    Jul 9, 2014
    79
    Thank you Jonathan,
    This is a great idea and makes perfect sense. I will look at the templates and see how the directory is set up, and see if I can copy the config for the alternate site. If I run into problems or have additional questions I'll contact you.
    Thank you again!,
    --John
  4. tratz
    tratz New Member
    Oct 21, 2015
    111
    16
    It is also possible with Fanvil X5g phones with a script as the formatting as been slightly different than what the 3cx phone book delivers.
