Bridging Grandstream with 3cx
Discussion in '3CX Phone System - General' started by Basheerpt, Oct 24, 2017.
  1. Basheerpt
    Feb 15, 2017
    49
    7
    Just wondering anybody here who did bridging the grandstream with 3cx. It's a customer requirement and we have to go with it, they have reason for that.
    However, we tried to configure it by creating new SIP trunk, but the call from Gransdstream network, goes to IVR instead of going directly to the user extension.
    Anybody has idea what is wrong here? My aim is to from Grandstream phone, call directly to the extension inside the 3cx network. Both network are reachable and with separate dialing numbers.
    Thanks for the support.
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @Basheerpt
    If i understood your situation well, you can do this by setting the preferred DID in Extensions>>General>>Direct Inbound Dialing(DID)
  3. Basheerpt
    Feb 15, 2017
    49
    7
    Hi loanissM,
    Thank you for your quick reply. I could not find this option in the Extension>General settings. I am still on V. 14. Where u referring on V.15 or Grandstream?
    Thank you again
  4. IoannisM_3CX
    Aug 10, 2017
    229
    18
    kindly note that Version 14 is unsupported as per support procedures, please upgrade, preferable to the latest version when possible.
    Thank you
  5. Basheerpt
    Feb 15, 2017
    49
    7
    Hi loannis,
    I am ready to upgrade but some of the feature I am using now not available in the current version. So, waiting for the update 2.
    Thank you.
    IoannisM_3CX likes this.
  6. IoannisM_3CX
    Aug 10, 2017
    229
    18
    That would be the best choice
  7. Basheerpt
    Feb 15, 2017
    49
    7
    Hi again loannisM,
    We tested it on a test setup, still no luck. Call goes to IVR. any other possibility?
    Thank you
  8. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    If I understand, you have a UCM bridging with 3CX using a peer trunk between the two. Presumably, each PBX is using a different set of user extension ranges and you have outbound rules set accordingly in each system so that calls to the other will make their way across. The issue is that when they arrive at 3CX, the system is sending the call to an IVR rather than the dialed extension? I assume that the dialed extension is not the IVR extension. You may need to do a wireshark capture and then see what the message looks like and then adjust the 3CX inbound parameters on the peer trunk so that 3CX is picking up the desired header info to route correctly.
  9. leejor
    10,744
    281
    Did you set up as a Bridge Trunk in 3CX as in ...https://www.3cx.com/docs/bridging-asterisk-pbx/
    What does the 3CX Activity Log show for the incoming calls? That should indicate why they go where they do.
  10. Basheerpt
    Feb 15, 2017
    49
    7
    @lneblett
    Your got the scenario exactly. This is what we need.
    @leejor
    Thanks for that. We will have a look at that document.
