Bridging Servers - How do calls Route?
Discussion in '3CX Phone System - General' started by pjr, Dec 3, 2009.
  1. pjr
    pjr New Member
    Oct 5, 2009
    154
    If I bridge 2 3CX servers, do calls between the servers route through the servers (ie PBX delivers Audio), or if the 2 servers are on a routed solution (ie VPN) and the SIP endpoints can see each other, do the calls route directly between the phones?
    I am trying to ascertain if we can bridge 2 servers and still allow the use of G722 codec for calls on phones that support it, even if they are on different 3CX systems?
    Paul
  2. abundisnet
    Sep 23, 2009
    18
    Yes, you can use that codec on both server. You need to have installed the codec in both servers and make it the only or first codec on the codecs list.
  3. pjr
    pjr New Member
    Oct 5, 2009
    154
    I think you misunderstand - 3CX doesnt support G722 but the phones we use do.
    If the call HAS to go via 3CX then I lose HD (G722) calls between phones in bridged sites. If the calls go directly between endpoints rather than via the server, I can retain the use of HD calling (G722).
    Paul
  4. abundisnet
    Sep 23, 2009
    18
    I´m sorry, yes I misunderstand, thinking we can add any codec just like other pbx.
    Please check this tread.
    http://www.3cx.com/forums/g-722-codec-9134.html
