Bring Back column status in v15
Discussion in 'Ideas' started by fpernice, Aug 17, 2016.
Bring Back column status in v15 5 5 4votes
5/5, 4 votes
  1. fpernice
    Sep 6, 2013
    8
    The extensions view in v14 showed us the status of each extension in a column. Now we have to click on each line then Status to know the value. This is not very convenient!
  2. cdrichla
    May 25, 2008
    33
    Yes, I agree. This is critical for remote administration. Their answer is to use the phone client but that is not a solution from a system administration standpoint.
  3. hogan71088
    Nov 30, 2015
    62
    +1 this is a must.
  4. aelford
    Oct 7, 2016
    5
    I also agree - I had created new topic for the same request which can be merged with this one
  5. mazingtree
    Oct 13, 2011
    10
    I agree. I do see that from the dashboard you can click on call in use button, but that's just not so intuitive as the calls indicator lights.
