Bring back the ability for PBX to find vacant extensions
Discussion in 'Ideas' started by pointsoft, Feb 13, 2018.
  1. pointsoft
    Oct 22, 2014
    Our extension range starts from 1000, the pbx on the previous version would find vacant extensions at above 1000 range and use that so i wouldnt have to search through it
  2. the60
    the60 New Member
    Oct 21, 2011
    117
    56
    For the time being, you'll need to set up 1000 "dummy" extensions. That's what I had to do.
    CSV import makes the process moderately tolerable.
