BroadVoice - Cant Register
Discussion in '3CX Phone System - General' started by terryferguson, Jan 24, 2008.
  1. terryferguson
    Jan 24, 2008
    Just SIgned up for Broadvoice BYOD service.
    Trying to Get Resistered on their system but keep getting Registration failed.
    WHAT'S UP
    I configured new voip, broad voice, config prox no luck.
    Following other post, I do have two ip addresses on the box
    Local plus Hamachi for remote access.
    3cx works fine, just trying to get outside line up
    Firewall test passed, warnings on re-assigned port numbers?
    Will try tonight at home, remoting from work.
  2. terryferguson
    Jan 24, 2008
    Server Logs
    3CX Phone System Version5.0.3790.0 PBX FAX DB DR MS VM WEB
    The server log shows server activity and detailed logging Messages. More > These log messages can allow you to troubleshoot firewall, VOIP gateway, VOIP provider and SIP phone configuration issues. When requesting support, always post the relevant server status logs for a particular issue. < Less
    Time Function Message
    14:01:58.050 ClientRegs::eek:nFailure [CM504007]: Next attempt to register 10000@BroadVoice is scheduled in 1 minute
    14:01:58.050 ClientRegs::eek:nFailure [CM504005]: Registration failed for: 10000@BroadVoice
    14:01:57.910 ClientRegs::Register [CM504003]: Sent registration request for 10000@BroadVoice
    14:01:55.691 ClientRegs::eek:nFailure [CM504007]: Next attempt to register 10000@BroadVoice is scheduled in 1 minute
    14:01:55.691 ClientRegs::eek:nFailure [CM504005]: Registration failed for: 10000@BroadVoice
    14:01:55.597 ClientRegs::Register [CM504003]: Sent registration request for 10000@BroadVoice
    14:01:54.644 ClientRegs::eek:nFailure [CM504007]: Next attempt to register 10000@BroadVoice is scheduled in 1 minute
    14:01:54.644 ClientRegs::eek:nFailure [CM504005]: Registration failed for: 10000@BroadVoice
    14:01:54.535 ClientRegs::Register [CM504003]: Sent registration request for 10000@BroadVoice
    14:01:45.050 ClientRegs::eek:nFailure [CM504007]: Next attempt to register 10000@BroadVoice is scheduled in 1 minute
    14:01:45.050 ClientRegs::eek:nFailure [CM504005]: Registration failed for: 10000@BroadVoice
    14:01:44.957 ClientRegs::Register [CM504003]: Sent registration request for 10000@BroadVoice
    14:01:44.004 ClientRegs::eek:nFailure [CM504007]: Next attempt to
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,939
    250
    This would point to some problem with your BroadVoice account or credentials being entered wrongly. 3CX works well with Broadvoice...
