Broadvoice Line unregistering
Discussion in '3CX Phone System - General' started by pkothe, May 31, 2007.
  1. pkothe
    Feb 2, 2007
    39
    My Broadvoice line is unregistering on its own after a period of time which I have not nailed down yet. One of the people who use this line complained that they are unable to use it frequently. I have started looking at it more and it is not registered. I manually register it and it registers fine. Any ideas how I can keep this from unregistering?
    Paul
  2. Anonymous
    Anonymous Guest
    I had the same problem with the SIP line.
    Recreated the line (Deleted it and than created it again).
    Time between registrations set that to 240 seconds.
    I have the funny feeling that if your registration request does not match your ATA or standard of the VSP it might cause some issues. But that is a BIG assumption I have no Facts for that.
