broadvoice
Discussion in '3CX Phone System - General' started by robbrevere, Jun 28, 2007.
  1. robbrevere
    Jun 28, 2007
    ok... i enter the correct information yet 3cx will not register. I was able to get the extention to register but not 3cx.
    Code:
    20:22:38.703  	ServRegs::onRemove  	[CM113003] Unregistered: Ext.101
    20:18:42.578 	ClientRegs::onRequestRetry 	[CM113008] Registration attempt for Ln:10000@Broadvoice is scheduled in 240 sec.
    20:16:10.281 	ClientRegs::onRequestRetry 	[CM113008] Registration attempt for Ln:10000@Broadvoice is scheduled in 120 sec.
    20:15:36.890 	ExtLine::Register 	[CM110004] Send registration for <sip:9793534002@sip.broadvoice.com>
    20:15:36.890 	ExtLine::Register 	[CM110001] Use External IP for device line registration DN='10000' device='Broadvoice'
    20:06:09.750 	DBUpdateListener 	[CM100006] Unregistering line: DN=10000
    20:05:32.515 	ClientRegs::onFailure 	[CM113010] Next registration will be attempted in 10 minutes
    20:05:32.500 	ClientRegs::onFailure 	[CM113006] Registration of sip:9793534002@sip.broadvoice.com has failed; reason=Request Timeout
    20:05:32.156 	ClientRegs::onFailure 	[CM113010] Next registration will be attempted in 10 minutes
    20:05:32.156 	ClientRegs::onFailure 	[CM113006] Registration of sip:9793534002@sip.broadvoice.com has failed; reason=Request Timeout
    20:05:07.468 	ClientRegs::onFailure 	[CM113010] Next registration will be attempted in 10 minutes
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Sir I will need a bit more info that that to help you
    You tried to add Broadvoice as provider using the Broadvoice template in the "add Voip Provider" section?
    Does your machine have 2 network cards? one to internet, and one to local network?
