BroadVox & outbound caller ID
Discussion in '3CX Phone System - General' started by Tech_Shield, Apr 15, 2009.
  1. Tech_Shield
    Feb 24, 2009
    Does anyone have outbound caller ID working with a BroadVox SIP trunk?
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    We need to make a custom fix to your Db to get this working. Alternatively you will need to wait for the next build to have this running.
    Please open a support ticket if you need the fix made.
