Broadvox SIP Trunk (registered) cannot place outbound calls
Discussion in '3CX Phone System - General' started by jvivona, May 18, 2014.
  1. jvivona
    May 18, 2014
    26
    10
    testing 3cx software with out existing systems, we use Broadvox with out current system, have validated ids and passwords. When we create a new provider and enter the information correctly, we CAN receive inbound calls and we get 2 way audio - no problems. But we cannot place outgoing calls. we get the following in the system log.
    If I force a bad password, I get 403 error as expected.
    I've turned off STUN, put the server directly on the network - opened ALL ports on our firewall for the NAT mapping.
    Any thoughts would be appreciated
    Code:
    17-May-2014 12:03:05.809	[Flow] Current call diversion path:[]
    17-May-2014 12:03:05.809	L:2.1[Extn] failed to reach Out#:>>Rule{Rule for Broadvox}>>97705141640, reason Not Registered
    17-May-2014 12:03:05.809	RerouteReq
    17-May-2014 12:03:05.808	[CM503016]: Call(C:2): Attempt to reach <sip:97705141640@10.168.111.15:5060> from Extn:111 has failed. Reason: Not Registered
    17-May-2014 12:03:05.808	[CM503017]: Call(C:2): Target is not registered: Out#:>>Rule{Rule for Broadvox}>>97705141640
    17-May-2014 12:03:05.808	Call(C:2): Call from Extn:111 to 97705141640 matches outbound rule 'Rule for Broadvox'
    17-May-2014 12:03:05.808	[Flow] Call(C:2): has built target endpoint: Out#:>>Rule{Rule for Broadvox}>>97705141640 for call from L:2.1[Extn]
    17-May-2014 12:03:05.808	[Flow] Target endpoint for 97705141640 is Out#:>>Rule{Rule for Broadvox}>>97705141640
    17-May-2014 12:03:05.808	Selected prefix: 9
    17-May-2014 12:03:05.808	Looking for outbound rule: dialed = [97705141640], processed: [97705141640]; from-ext:
    17-May-2014 12:03:05.808	[Flow] Building target endpoint to 97705141640 from "Joe Vivona" <sip:111@10.168.111.15:5060>
    17-May-2014 12:03:05.808	[CM503010]: Call(C:2): Making route(s) from Extn:111 to <sip:97705141640@10.168.111.15:5060>
    17-May-2014 12:03:05.808	Remote SDP is set for leg L:2.1[Extn]
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Re: Broadvox SIP Trunk (registered) cannot place outbound ca
    I would try to strip 1 digit, It looks like your trying to call an atlanta number which is 770 correct? If so you need to strip one digit because your pbx is sending a 9 ahead of the number, so its probably not being recognized by Broadvox as a valid phone number.
  3. jvivona
    May 18, 2014
    26
    10
    Ahhh... thought it would have done it automatically considering that was the route rule...
    That solved the issue. Thanks so much! Now on to bigger testing issues...
