Broken packages
All Gods Children
Is anyone else experiencing broken packages after upgrade to SP3? I upgraded through the web gui and received an email that it was done. However, I still see the "update available" on the web gui. I tried to upgrade through command line, but receive the error below. Any ideas? :confused:
Code:
apt-get upgrade 3cxpbx
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 postgresql-9.4 : Depends: libssl1.0.0 (>= 1.0.0) but it is not going to be installed
 postgresql-client-9.4 : Depends: libssl1.0.0 (>= 1.0.0) but it is not going to be installed
E: Broken packages
Why not apt-get upgrade and upgrade all the dependencies?
apt-get update followed by apt-get upgrade
leave out the 3cxpbx part and all programs are updated
Sorry forgot to mention that. I've tried that as well and receive the error below.
Code:
apt-get update
Hit:1 http://security.debian.org stretch/updates InRelease
Ign:2 http://cdn-fastly.deb.debian.org/debian stretch InRelease
Hit:4 http://downloads.3cx.com/downloads/debian stretch-testing InRelease
Hit:3 http://cdn-fastly.deb.debian.org/debian stretch-updates InRelease
Hit:6 http://downloads.3cx.com/downloads/debian stretch InRelease
Hit:5 http://cdn-fastly.deb.debian.org/debian stretch Release
apt-get upgrade
The following packages have been kept back:
  3cxpbx libcurl3 linux-image-amd64
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
I was able to resolve this issue by removing 3CX, reinstalling, and restoring from a backup. I guess it was an update corruption from previous version.
I am having this same issue with my upgrade to SP3. I will remove and reinstall. Thank you.
same problem here, can you post how you removed and reinstall?
Might want to wait until they fix the log problem. I wish I hadn't upgraded.
Getting Started - Admin
YBow
Get 3CX - Absolutely Free!
3CX
