BT (British Telecom) Configuration
Discussion in '3CX Phone System - General' started by simonhc, Dec 19, 2011.
  1. simonhc
    Dec 9, 2011
    41
    I am trying to configure 3cx with BT. I have read that some poeple have managed to get this working however I am not one of them.
    Incoming calls work perfectly, however when I try outgoing calls they show the message "Invalid number" on the phones display and then disconnect.
    I am using 3cx v10.0.22686.2297 SP.5 with a Cisco 509g firmware 7.4.9c
    The Server Log is at time of call is:
    10:32:12.516|.\CallCtrl.cpp(346)|Log2||CallCtrl::eek:nIncomingCall:[CM503001]: Call(115): Incoming call from Ext.1303 to <sip:07785951725@192.168.1.12><br>
    10:32:12.516|.\Extension.cpp(1407)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.1303: Device info: Device Identified: [Man: Cisco;Mod: SPA Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco/SPA509G-7.4.9c] PBX contact: [sip:1303@192.168.1.12:5060]<br>
    10:32:12.532|.\CallCtrl.cpp(529)|Log3||CallCtrl::eek:nSelectRouteReq:[CM503010]: Making route(s) to <sip:07785951725@192.168.1.12><br>
    10:32:12.532|.\CallCtrl.cpp(651)|Log2||CallCtrl::eek:nSelectRouteReq:[CM503014]: Call(115): No known route to target: <sip:07785951725@192.168.1.12><br>
    10:32:12.532|.\Call.cpp(1091)|Log2||Call::RouteFailed:[CM503016]: Call(115): Attempt to reach <sip:07785951725@192.168.1.12> failed. Reason: Not Found<br>
    10:32:12.532|.\Call.cpp(605)|Log2||Call::DoEndCall:[CM503020]: Normal call termination. Reason: Not found<br>
    Any help would be appreciated
    Simon
    10,375
    231
    This seems to indicate that you do not have an outbound rule that matches with the number you are dialling. Post your outbound rule(s), and the numbers (format) you wish to dial, if you don't get it working.
  3. simonhc
    Dec 9, 2011
    41
    Hi Leejor,
    Thank you so much for that, you where absolutely correct it was my outbound rule causing the problem. Once I had it setup correctly everything worked as expected.
    Thanks again
    Simon
