BT Business SETUP HELP Please.
Discussion in '3CX Phone System - General' started by jamieshankland, Apr 11, 2011.
  1. jamieshankland
    Aug 10, 2009
    10
    I posted in another topic with no success, and the title of the topic was wrongly named so I hope you guys dont mind me posting again so people can correctly read the topic and might encourage more people to send me a message.
    Here is the list of settings BT supplied me with.
    http://api.home/voipsetup.api?SIPTransportProtocol=UDP
    SIPTransportPort=5060
    SIPRegistrarAddress=bmnhb-03.bt.com
    SIPRegistrarPort=5060
    SIPOutboundProxyAddress=www.bbvservice-560345.bt.com
    SIPOutboundProxyPort=5060
    SIPProxyAddress=bmnhb-03.bt.com
    SIPProxyPort=5060
    SIPPhoneNumber1=0560*******
    SIPCallerName1=
    SIPUsername1=05603******
    SIPPassword1=*******************
    Here is the details I recieved from bt... currently I have the phone working via my bt router (that they provided me) you plug the phone in the back of the router and thats it your connected.
    So I installed the 3CX software on my pc and I went to VOIP setup
    In the
    SIP Server hostname or IP box I put bmnhb-03.bt.com port 5060
    Outbound proxy I put http://www.bbvservice-560345.bt.com port 5060
    External Phone number I put my telephone number 01382-123456(for example)
    Authentication Password i put the password provided by BT
    so after I done all that I clicked on save.
    Now for the log that I am getting.
    3:57:50.921 [CM504001]: Ext.IVRForward: new contact is registered. Contact(s): [sip:IVRForward@127.0.0.1:40600;rinstance=b0acdf6a515c9f51/IVRForward]
    13:57:50.921 [CM504001]: Ext.EndCall: new contact is registered. Contact(s): [sip:EndCall@127.0.0.1:40600;rinstance=73ff3ba8c6342288/EndCall]
    13:57:50.905 [CM504001]: Ext.800: new contact is registered. Contact(s): [sip:800@127.0.0.1:40600;rinstance=4f26f6639d335e84/800]
    13:57:50.889 [CM504001]: Ext.999: new contact is registered. Contact(s): [sip:999@127.0.0.1:40600;rinstance=d6aff72036195431/999]
    13:57:50.827 [EC100007]: External application is connected: application:user-d1d5bfd410:0/InterfaceWindows local:127.0.0.1:5482 remote:127.0.0.1:1203
    13:57:38.639 [CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*1@127.0.0.1:40000;rinstance=279450fe761e4c9f/*1]
    13:57:38.639 [CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*0@127.0.0.1:40000;rinstance=d24be6fb99a10cf6/*0]
    13:57:38.624 [CM504001]: Ext.*777: new contact is registered. Contact(s): [sip:*777@127.0.0.1:40000;rinstance=67ff0827c68102c6/*777]
    13:57:38.483 [CM504004]: Registration succeeded for: 10000@BT BUSINESS
    13:57:36.217 [CM504008]: Fax Service: registered as sip:888@192.168.1.121:5060 with contact sip:888@192.168.1.121:5100;user=phone
    13:57:35.749 [CM504003]: Sent registration request for 10000@BT BUSINESS
    13:57:33.421 IP(s) added:[192.168.1.121]
    13:57:30.624 [EC200006]: Conference server is connected: application:user-d1d5bfd410:0/3CXConferenceRoom local:127.0.0.1:5482 remote:127.0.0.1:1199
    13:57:30.186 [CM504004]: Registration succeeded for: 10000@BT BUSINESS
    13:57:29.999 [EC200004]: IVR server is connected: application:user-d1d5bfd410:0/IVRServer local:127.0.0.1:5482 remote:127.0.0.1:1197
    13:57:28.858 [EC200002]: Media server is connected: application:user-d1d5bfd410:0/MediaServer local:127.0.0.1:5482 remote:127.0.0.1:1196
    13:57:28.155 [EC200005]: Parking Orbit server is connected: application:user-d1d5bfd410:0/3CXParkOrbit local:127.0.0.1:5482 remote:127.0.0.1:1195
    13:57:27.796 [EC100007]: External application is connected: application:user-d1d5bfd410:0/QueueManager local:127.0.0.1:5482 remote:127.0.0.1:1194
    13:57:27.280 [CM504003]: Sent registration request for 10000@BT BUSINESS
    13:57:24.639 [CM506002]: Resolved SIP external IP:port (86.143.203.249:5060) on Transport 192.168.1.121:5060
    13:57:24.467 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.1.121:5060
    13:57:23.342 Failed to obtain short path name for [C:\Documents and Settings\All Users\Application Data\3CX\Bin\Cert]
    13:57:23.342 [CM501006]: Default Local IP address: [192.168.1.121]
    13:57:23.342 [CM501002]: Version: 9.0.15776.0
    13:57:23.342 [CM501007]: *** Started Calls Controller thread ***
    13:57:23.342 [CM501001]: Start 3CX PhoneSystem Call Manager
    13:57:22.999 [EC200001]: Configuration server is connected: application:user-d1d5bfd410:5485/DBProvider local:127.0.0.1:1191 remote:127.0.0.1:5485
    13:57:22.874 [CM501010]: License Info: Load Failed
  2. willow
    willow Member
    Mar 1, 2011
    471
    so what is the issue. it appears that the sip trunk is regestering as by the 10000@bt line. I don't think that you will be able to use the analog terminal in there router and the PBX at the same time though.
  3. jamieshankland
    Aug 10, 2009
    10
    The problem is when you phone the number it wont work.
    I can try another router on it to see if that works.
    Is the phone registering though??
  4. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    if you have the BT Home Hub and Hub Phone, you wont be able to get the Hub phone to work with 3CX, you can get BT to work on 3CX, but you will need to use another IP Phone.
