BT Home Hub 3
Discussion in '3CX Phone System - General' started by aftermarket, Jun 14, 2012.
  1. aftermarket
    May 13, 2009
    84
    hey guys,
    trying to install this using a bt home hub on infinity broadband (unable to change the router as its using fibre, unless anyone else knows of router that can do the job on fibre). The problem is im only getting one way audio. i have the router forwarding to the pbx server call comes in and only one way audio. any ideas?
    cheers
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    179
    1) Inbound 5060 UDP/TCP
    2) Inbound 9000-9049 UDP
    3) I found it helps to open all ports outbound from 3cx IP to ALL External.
  3. aftermarket
    May 13, 2009
    84
    hi craig theyve been opened and forwarded from the router to the 3cx box.
    or do you mean on the firewall of windows?
  4. craigreilly
    Feb 1, 2012
    2,947
    179
    I keep Windows Firewall off.
  5. aftermarket
    May 13, 2009
    84
    tried it with it off as well. im thinking its the router losing things
  6. craigreilly
    Feb 1, 2012
    2,947
    179
    Does your router show any logs or traffic reports?
    I can specify an IP on mine and see if traffic is being blocked.
  7. paul.hadley
    paul.hadley New Member
    Aug 24, 2010
    122
    I have done a setup on a BT Home Hub 3 without any problems.
    If you do want to change the router I believe any router (Non ADSL) with a Ethernet connection to the modem can be used.
    Which way is your one way audio, I would guess callers can hear you but you can not hear them.
    The most likely problem is a setting in 3CX sending out the wrong IP address (internal) so that external servers can not sent you an audio stream, check your logs.
