bt home hub
Discussion in '3CX Phone System - General' started by deustheprogrammer, Mar 18, 2010.
  1. deustheprogrammer
    Mar 18, 2010
    hi i have a bt home hub and 3cx installed, i would like to use sipgate with 3cx is this possible and if so any tutorials on how to set it up? very new to ip telephony,
    thanks
    deus
    11,129
    330
    As long as the BT Home Hub allows you to forward the needed ports to the PC running 3CX, and isn't blocking any (for what ever reason), then there should be no reason why you couldn't add a Sipgate trunk.
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
  4. penzance
    Mar 15, 2009
    Hmmm. I'm having the same problem. Firmware: Software version 8.1.H.J (Type A)
    It seems I'm going to have to change the client's router, as the Homehub has built-in VOIP and (probably) has been set up in such a way as to prevent competing VOIP services...
  5. andymars
    Jan 12, 2010
    47
    exactly the problem i faced, replace the router :)
  6. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Didnt realise you were chasing it to use it as a phone with 3CX, I highly doubt BT has such devices open for use as you are saying. Best of luck!
