BT SIP Trunk
Discussion in '3CX Phone System - General' started by IanD, Apr 11, 2017.
  1. IanD
    Mar 2, 2017
    Has anyone managed to get hold of an XML config file for a BT SIP trunk? They are listed as a SIP Trunk Provider (https://www.3cx.com/partners/sip-trunks/uk/), but they do not appear in the list of available SIP providers, even in the latest update of v15. BT Wholesale apparently can't provide a copy of the XML file and I can't make the connection work correctly with the Generic SIP config. I can't see the point of BT being listed as a SIP trunk provider if it doesn't work!
    Thanks in advance.
  2. DL_
    DL_
    Mar 31, 2015
    55
    8
    I'd be looking to use 3cx with BT SIP when we deploy so would also be interested in this. I noticed that it wasn't listed as a SIP provider in the software config and that seemed strange based upon their blog entry in September https://www.3cx.com/blog/news/uk-voip-provider-bt/ which seemed to say they had tight integration.
  3. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    I'm not sure you are intended audience?:confused:
    • Your customers will then be able to make simultaneous calls over the Internet or a dedicated IP network.
