BT Sip? Will it work
Discussion in '3CX Phone System - General' started by Schrodz, Apr 26, 2017.
  1. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    Does anyone know if a BT Sip Trunk will work with 3cx.
    Kind Regards,
    Daniel Schroeder
    10,869
    304
    A long time ago someone asked the same thing, with no responses. I would guess that for business customers, yes, but residential service, no. https://www.3cx.com/blog/news/uk-voip-provider-bt/
    You might just ask them directly. If they won't provide you with things such as a password, user name, server address, then you know that they want you to use their hardware, but they should be able to tell you that. If they insist that you use their ATA, then you could Gateway it into 3CX. Not the most economical, but it would work.
