BT (UK) FeatureLine
Discussion in '3CX Phone System - General' started by Resolve, Feb 26, 2008.
  1. Resolve
    Sep 19, 2007
    94
    Anyone had any specific problems with Featureline - such as unable to make concurrent outgoing calls vis patton 4114 etc?
    Thanks,
    Tim
  2. Resolve
    Sep 19, 2007
    94
    Just to answer my own post :p
    BT Featureline system works fine with 3cx/patton 4114.
    Tim 8)
  3. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    nice to hear that works properly
    cheers
  4. colin2710
    Oct 29, 2007
    28
    Hi there,
    We had 3CX working with Feature Line, the only problem we did have was with CLI - it kept disappearing. We rang BT and they did something and it worked very well.
    Regards - Colin - colin2710
