BT101 and paging
Discussion in '3CX Phone System - General' started by beaver, Jun 20, 2008.
  1. beaver
    Aug 2, 2007
    30
    I´m ussing a bt101 and i want to know if there is a possibiliti to make them work with pagging since they don´t have the
    Allow Auto Answer by Call-info function?
  2. beaver
    Aug 2, 2007
    30
    Yes you are right but I decided to use that model a while ago when paging was neither in the wish list. And that feature really looks interesting so i want to give a try.
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Availability of this feature completely depends on phone capabilities. We has no other way to force phone autoanswer if it doesn't aupport autoanswer on Call-Info.
