BUG call queue - **Not FIXED with SP4
Discussion in '3CX Phone System - General' started by bluetel2, Jul 21, 2010.
  1. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    Hi all,
    exist bug with call queue. some times, call rest in the call queue and when user answer it's not work and call conitnue to run in call queue it's impossible to answer there is answer, and it's impossible to cut call because the caller have cut call since long time... call exist but the caller is not on a call....
    exemple : n° 105 make call to 122, 122 is on line and forward rule said go to call queue 801, next caller (105) end call, but call rest in call queue and turn on the all extensions which are on call queue, when this extension answer call, it's not work and call turn again in other extension. the only wait to cut call it's restart all services or juste call queue manager.
    i can send the log.
    tks
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Re: call queue
    Hi, what version of PBX are you using.
    This was a known issue and was fixed with the latest version RC2.
  3. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    Re: call queue
    oups yes we have the 9.0.133773.540
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Re: call queue
    Yes, then upgrade to Build number 13545, and let us know.
    Thanks and Regards
  5. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    Re: call queue
    Ok tks
    regards
  6. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Re: call queue ** FIXED IN RC2
    This should be fixed in the latest version.
    BTW - thanks for the help you provided in some other posts. Much appreciated. If you need anything let us know. That backup you had helped us solve and replicate a lot of issues.
  7. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    hi Nickybrg,
    it's with plaisure. 8)
    in fact i have installed last version and bug is not present. tks so much.
  8. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    Re: call queue - **FIXED In RC2
    hi all,
    again in this post :'( ... i have the last version and it's not really fix. problem exist again. sorry
  9. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Can you describe what happens now in this case? The queues go unregistered or what? can you send us the logs? Event logs? or the backup?
    Does it happen immediately or after a period of operation?
  10. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    a call arrive in queue, and caller end call, but call turn on the call queue and ringing to agent 1 after 1. when agent want to take call, call leave and continue ti ringing on other agent....etc... impossible to take call. to stop it i must restart call queue manager service.
    i have don't log, in this moment. next time i will save it. you have the backup, it's the same that last time.
    Does it happen immediately or after a period of operation? -> pbx run since last installation of rc2 final. we can said 2 days maybe for the first time and maybe 22 or 3 days for the second time (first time i have restart all services). 2 or 3 days we received maybe 100 calls in call queue.
    tks
  11. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    What type of call? External (PSTN/VOPIP PROVIDER) to the queue?
    does it happen if you had to dial the queue from an internal extension just as a test?
    So correct me if I am wrong.
    USER X makes Incoming call -> 3CX QUEUE.
    Question - What is the queue in question? HUNT or ring all?
    USER X disconnects. Call remains in queue ringing members?
    Why impossible to take call? If you answer what happens? Call disconnects or there is no audio? Does ringing stop?
  12. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    first time it's external, last internal. queue work every time, it use for internal or external call to join commercial service. 5 users are connected. it's happened every time (if a remember but not 100% sure) when caller end call,because all users are not avalaible or busy.
    it's hunt queue and when user X end call members received ringing and can't take call, when they take it call going to another extension (ringing in other ext) and it's the same result when agent want take call.
    when we answer it's like i said before, the call go to another extension and yes important my customer (USER X) has cut call since long time, user x is not in wainting time, he is not on line. cut call exist again.
    tks
  13. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    no one see again this bug ? just me ? :cry:
  14. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    hi all,
    bug exist again. i send you per mp the log file and the wireshar file
    to leonidas G.
    tks
  15. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    Could you try updating to the latest build Online? RC2 was a really old build.
  16. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    the version installed is v9.0.13545.594 sp1
    it's not the last version ?
    tks avance
  17. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    Re: call queue - **NOT FIXED In SP3
    Hi all,
    i'm come back again for this post. we have the last version of 3cx, all service pack are installed... the bug where calls are block in call queue exist again. it's not resolve.it's impossible to answer call, when we answer it go to other agent etc... call doesn't exist in gateway inbound call, it exist only in call queue. to drop it we must restart call queue service
    mp if you want log.
    tks
  18. bangsjaman
    Jun 1, 2009
    37
    I have actually also experienced exactly the described problem.
    It happens randomly and is pretty hard to back trace. It happens only every 2-3 days, and log doesnt give me any clue.
    But I have noticed the following. Even that restartning queue manager seems to solve the problem, when I look at System Extension Status afterwards, a Queue (820) is constantly dialing out. See picture.
    If I select the call and try to disconnect, I get this error:
    Benjamin
      File size:
      7.5 KB
      1,517
      File size:
      10.1 KB
      1,517
  19. Welzo
    Nov 11, 2010
    12
    Re: BUG call queue - **Not FIXED with SP3
    We have the same problem as the post above.
    Here is what we think happened:
    1 - An extenal customer call in (queue with Prioritized Hunt)
    2 - (430) pick up the call
    3 - Hold the customer (HOLD key on GXP 2000)
    4 - Call an external (mobile) number
    5 - External (mobile) number responds to the call
    6 - The customer is tranferred to the mobile number (using TRNF --> LINE1 on the GXP 2000)
    7 - The operator (430) hang up his phone
    8 - External mobile number and the customer are talking and the BLF key of the operators extension (430) is showing BUSY on all phones.
    9 - Even after the call ended we still have the Extension Status on the 3CX Console of extension (430) set to "CONNECTED" to the incoming call of the customer. And still the BLF of the operators extension (430) is showing BUSY.
    Even in the Server Activity Log it doesn't show any active calls but the call is still connected to the extension somehow.
    10 - When trying to Disconnect Call in the Console we also get the same exception "An exception occurred ExtStatus Error:"
    We will restart the server/services later today since it is very annoying that the extension's BLF is shown BUSY all the time on all of our phones.
  20. LeonidasG
    Nov 19, 2008
    1,406
    81
    I'm unable to reproduce the issue with the call scenario you gave.
    Can you possibly upgrade your Grandstream's Firmware to the latest available from the Grandstream website and see what happens?
