[Bug] Caller ID not passed when rinigng cell/ext
Discussion in '3CX Phone System - General' started by KerryG, Aug 10, 2010.
  1. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    The new feature to ring both the mobile and the extension at the same time is not passing the original caller id, instead it passes the PBX's main phone number.
  2. matictec
    matictec New Member
    Mar 31, 2008
    188
    can confirm the beahvior. after this has been fixed for calls that forward to mobile (also for queue calls) this has to been fixed to make this feature more usefull.
