Bug: Client Displays deleted extensions
Discussion in 'Windows' started by crsc, Jan 17, 2008.
  1. crsc
    Dec 1, 2007
    28
    Clent v5.0.3763M.0
    Server v5.0.3790.0
    Deleted extension are displayed. Status is ramdom. The extensions don't exist in the extension table.
