Bug? Exception error**FIXED RC2
Discussion in '3CX Phone System - General' started by sssputnik, Jul 15, 2010.
  1. sssputnik
    Apr 21, 2010
    25
    Just installed the version 9 release and restored a backup from latest ver 8 system.
    All the settings look good. I got a few warnings in a txt file popup that some rules could not be created and they would have to be manually entered.
    However....
    When I got to Extensions and open any extension number I get, "An exception occurred EditExtension Error: Object reference not set to an instance of an object." whenever I try to save the Extension settings, or even if I just open an Extension and hit Apply.
    The extension settings look OK.
    Any clues?
    Simon Shaw.
  2. sssputnik
    Apr 21, 2010
    25
    Re: Bug? Exception error.
    Found the problem, I had network disabled. Enabling allows settings to be saved!?
  3. nb
    nb Support Team
    Jun 7, 2007
    2,123
    150
    We will put a better message.
  4. nb
    nb Support Team
    Jun 7, 2007
    2,123
    150
    Should be fixed in RC2..
