Bug: Forwarding rule to "Same as External Calls"
Discussion in '3CX Phone System - General' started by giwm, Aug 16, 2017.
  1. giwm
    giwm New Member
    Sep 27, 2016
    217
    36
    15.5 SP1
    Under Forwarding Rules, when setting an exception with the rule, "Same as External Calls", you get the following error when trying to hit OK:
    Code:
    TCX.Configuration.Exceptions.ObjectSavingException: Commit failed on transaction Save Extension.276 - '1030'
       at TCX.Configuration.PhoneSystem.WBatchUpdater.Commit()
       at TCX.Configuration.Extension.DoSave(WBatchUpdater updater)
       at TCX.Configuration.DN.Save()
       at ConfigurationManagementModel.CfgExtensionEditor.Serialize_AfterSerialize(Object sender, SerializeEventArgs e)
       at ConfigurationManagementModel.PropertySerializer.Serialize(ICfgItemInternal cfgItem, SerializeParameters serializeParameters)
       at ConfigurationManagementModel.CfgItemBase.Save()
       at ManagementConsoleJS.Services.Editor.Save()
       at ManagementConsoleJS.Services.EditorService.SaveActiveObject(Int32 id)
       at ManagementConsoleJS.Controllers.EditController.Save(Int32 id)
       at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.d__28.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
       at Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.d__18.MoveNext()
       at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
       at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
       at Microsoft.AspNetCore.Builder.RouterMiddleware.d__4.MoveNext()
       at ManagementConsoleJS.Middleware.ExceptionWrapperMiddleware.d__3.MoveNext()
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    178
    I see same issue on 15.5 SP1 with Windows OS.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Thank you for reporting this. We will investigate the issue and report back once we have an update.
