Bug in Chrome WebRTC
Discussion in 'Windows' started by argenvoip, Oct 21, 2015.
  1. argenvoip
    Sep 19, 2011
    14
    Hello, I do not speak English, but I leave this help for those who have problems
    Bug in chrome, with the latest update. Some customers can not make calls WebRTC. The latest version of Chrome that works well WebRTC is: Version 45.0.2454.101
    No update or failing back to the old version of Chrome
    Greeting!
    Marcelo
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    Hi There,
    Due to a recent update in Google chrome the WebRTC feature will not work. You can either use firefox, or In order to solve this issue until SP2 we have a workaround that we can send to you, in the meantime, although this will require you to open a support ticket with us in order for us to send you the files required.
  3. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    SP2 resolves issues - so update to V14SP2
