Bug in concatenate component
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Mar 8, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Create a concatenation of four strings and click ok.
    Then reopen it, everything still being normal.
    Add an open or closed parenthesis in the 3rd string, then click ok.
    Now reopen it again and see that the last two strings have been stuffed into the 3rd box, and there are now only 3 strings.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi Shahzad,
    Thanks for reporting this. The fix will be available in the next VAD release.
    Regards,
  3. VAD_Support
    Aug 6, 2009
    690
    Hi Shahzad,
    This has been fixed in the latest release of the VAD.
    Thanks for your help to improve the product!
    Regards,
