Bug in Debug UI
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, May 3, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    While opening the treeview during debug, a bad index exception occurs. HEre's the screenshot, and I assume that this debug file will give you what you need...
    START_CALLFLOW_EXECUTION: Main.flow - Build: 270
    VARIABLE_CHANGED: application.Main_AllowNoAccountNumber=0
    VARIABLE_CHANGED: application.Main_AttemptNumber=1
    VARIABLE_CHANGED: application.Main_CallerID=
    VARIABLE_CHANGED: application.Main_LogMessage=
    VARIABLE_CHANGED: application.Main_MaxAttempts=5
    VARIABLE_CHANGED: application.Main_NextComponentUri$=
    VARIABLE_CHANGED: application.Main_NextDisconnectHandlerUri$=
    VARIABLE_CHANGED: application.Main_NextErrorHandlerUri$=
    VARIABLE_CHANGED: application.Main_StoreAccountNumber=
    VARIABLE_CHANGED: application.Main_StoreRsnNumber=
    VARIABLE_CHANGED: application.MenuResult_InvalidOption=InvalidOption
    VARIABLE_CHANGED: application.MenuResult_Timeout=Timeout
    VARIABLE_CHANGED: application.MenuResult_ValidOption=ValidOption
    VARIABLE_CHANGED: application.RecordResult_Completed=Completed
    VARIABLE_CHANGED: application.RecordResult_NothingRecorded=NothingRecorded
    VARIABLE_CHANGED: application.RecordResult_StopBySilence=StopBySilence
    VARIABLE_CHANGED: application.RecordResult_StopDigit=StopDigit
    VARIABLE_CHANGED: application.UserInputResult_InvalidDigits=InvalidDigits
    VARIABLE_CHANGED: application.UserInputResult_Timeout=Timeout
    VARIABLE_CHANGED: application.UserInputResult_ValidDigits=ValidDigits
    VARIABLE_CHANGED: application.project$_CurrentErrorDescription$=
    VARIABLE_CHANGED: application.project$_CurrentErrorName$=
    VARIABLE_CHANGED: application.project$_SystemDsnName=IVROnCall
    VARIABLE_CHANGED: application.project$_WorkOrderAudioPath=C:\ProgramData\3CX\Data\Work Order Audio
    VARIABLE_CHANGED: application.project$_WorkingDirectory$=C:\ProgramData\3CX\Data\Http\Interface\ivr\OnCall_Debug_270
    VARIABLE_CHANGED: application.project$_sqlDatabaseName=PBXDEV
    VARIABLE_CHANGED: application.project$_sqlDatabaseServer=Dataserver
    VARIABLE_CHANGED: application.project$_sqlPassword=pbx1
    VARIABLE_CHANGED: application.project$_sqlUser=pbx
    VARIABLE_CHANGED: session.ani=841
    VARIABLE_CHANGED: session.callid=From_841_To_844_Menu_844_#0/24
    VARIABLE_CHANGED: session.dnis=844
    END_EXECUTION: Main.flow - - MF
    VARIABLE_CHANGED: application.Logging_WriteLogEntry_LogMessage=New call from 841
    VARIABLE_CHANGED: application.Logging_WriteLogEntry_NextComponentUri$=Main_MF_logBeginCall_Suffix.vxml
    VARIABLE_CHANGED: application.Logging_WriteLogEntry_NextDisconnectHandlerUri$=Main_DisconnectHandler.vxml
    VARIABLE_CHANGED: application.Logging_WriteLogEntry_NextErrorHandlerUri$=Main_ErrorHandler.vxml
    VARIABLE_CHANGED: application.Main_logBeginCall_LogMessage=
    END_EXECUTION: Main.flow - logBeginCall - MF
    END_EXECUTION: Logging\WriteLogEntry.comp - - MF
    VARIABLE_CHANGED: Logging_WriteLogEntry_writeToIvrLog_ScalarResult=
    VARIABLE_CHANGED: Logging_WriteLogEntry_writeToIvrLog_NonQueryResult=0
    VARIABLE_CHANGED: Logging_WriteLogEntry_writeToIvrLog_QueryResult=
    END_EXECUTION: Logging\WriteLogEntry.comp - writeToIvrLog - MF
    VARIABLE_CHANGED: application.Main_logBeginCall_LogMessage=New call from 841
    VARIABLE_CHANGED: application.LoadConfigValues_AllowNoAccount=0
    VARIABLE_CHANGED: application.LoadConfigValues_NextComponentUri$=Main_MF_LoadConfigValues_Suffix.vxml
    VARIABLE_CHANGED: application.LoadConfigValues_NextDisconnectHandlerUri$=Main_DisconnectHandler.vxml
    VARIABLE_CHANGED: application.LoadConfigValues_NextErrorHandlerUri$=Main_ErrorHandler.vxml
    VARIABLE_CHANGED: application.LoadConfigValues_ivrQuery_GetStoreFromANI=
    VARIABLE_CHANGED: application.Main_LoadConfigValues_AllowNoAccount=0
    VARIABLE_CHANGED: application.Main_LoadConfigValues_ivrQuery_GetStoreFromANI=
    END_EXECUTION: Main.flow - LoadConfigValues - MF
    END_EXECUTION: LoadConfigValues.comp - - MF
    VARIABLE_CHANGED: LoadConfigValues_queryAllowNoAccountNumber_ScalarResult=
    VARIABLE_CHANGED: LoadConfigValues_queryAllowNoAccountNumber_NonQueryResult=0
    VARIABLE_CHANGED: LoadConfigValues_queryAllowNoAccountNumber_QueryResult=['False', 'SELECT * FROM dbo.fn_CallerIDLookup(\'{0}\',\'Store\') ']
    END_EXECUTION: LoadConfigValues.comp - queryAllowNoAccountNumber - MF
    VARIABLE_CHANGED: LoadConfigValues_AllowNoAccount=False
    END_EXECUTION: LoadConfigValues.comp - assignAllowNoAcount - MF
    VARIABLE_CHANGED: LoadConfigValues_ivrQuery_GetStoreFromANI=SELECT * FROM dbo.fn_CallerIDLookup('{0}','Store')
    END_EXECUTION: LoadConfigValues.comp - assign_GetStoreFromANI - MF
    VARIABLE_CHANGED: application.LoadConfigValues_logConfigLookup_LogMessage=
    VARIABLE_CHANGED: application.Logging_WriteLogEntry_LogMessage=Loaded config values: "Allow no account num" = False. "GetStoreANIQuery" = SELECT * FROM dbo.fn_CallerIDLookup('{0}','Store')
    VARIABLE_CHANGED: application.Logging_WriteLogEntry_NextComponentUri$=LoadConfigValues_MF_logConfigLookup_Suffix.vxml
    VARIABLE_CHANGED: application.Logging_WriteLogEntry_NextDisconnectHandlerUri$=LoadConfigValues_DisconnectHandler.vxml
    VARIABLE_CHANGED: application.Logging_WriteLogEntry_NextErrorHandlerUri$=LoadConfigValues_ErrorHandler.vxml
    END_EXECUTION: LoadConfigValues.comp - logConfigLookup - MF
    VARIABLE_CHANGED: application.LoadConfigValues_logConfigLookup_LogMessage=Loaded config values: "Allow no account num" = False. "GetStoreANIQuery" = SELECT * FROM dbo.fn_CallerIDLookup('{0}','Store')
    VARIABLE_CHANGED: application.Main_LoadConfigValues_AllowNoAccount=False
    VARIABLE_CHANGED: application.Main_LoadConfigValues_ivrQuery_GetStoreFromANI=SELECT * FROM dbo.fn_CallerIDLookup('{0}','Store')
    VARIABLE_CHANGED: application.Activities_CreateDynamicPrompts_EnterAccountNumberString=
    VARIABLE_CHANGED: application.Activities_CreateDynamicPrompts_MainGreetingString=
    VARIABLE_CHANGED: application.Activities_CreateDynamicPrompts_NextComponentUri$=Main_MF_createDynamicPrompts_Suffix.vxml
    VARIABLE_CHANGED: application.Activities_CreateDynamicPrompts_NextDisconnectHandlerUri$=Main_DisconnectHandler.vxml
    VARIABLE_CHANGED: application.Activities_CreateDynamicPrompts_NextErrorHandlerUri$=Main_ErrorHandler.vxml
    END_EXECUTION: Main.flow - createDynamicPrompts - MF
    END_EXECUTION: Activities\CreateDynamicPrompts.comp - - MF
    VARIABLE_CHANGED: application.Activities_CreateDynamicPrompts_logCreatingDynamicAudio_LogMessage=
    VARIABLE_CHANGED: application.Logging_WriteLogEntry_LogMessage=Creating dynamic files...
    VARIABLE_CHANGED: application.Logging_WriteLogEntry_NextComponentUri$=Activities_CreateDynamicPrompts_MF_logCreatingDynamicAudio_Suffix.vxml
    VARIABLE_CHANGED: application.Logging_WriteLogEntry_NextDisconnectHandlerUri$=Activities_CreateDynamicPrompts_DisconnectHandler.vxml
    VARIABLE_CHANGED: application.Logging_WriteLogEntry_NextErrorHandlerUri$=Activities_CreateDynamicPrompts_ErrorHandler.vxml
    END_EXECUTION: Activities\CreateDynamicPrompts.comp - logCreatingDynamicAudio - MF
    VARIABLE_CHANGED: application.Activities_CreateDynamicPrompts_logCreatingDynamicAudio_LogMessage=Creating dynamic files...
    VARIABLE_CHANGED: Activities_CreateDynamicPrompts_queryDynamicAudio_ScalarResult=
    VARIABLE_CHANGED: Activities_CreateDynamicPrompts_queryDynamicAudio_NonQueryResult=0
    VARIABLE_CHANGED: Activities_CreateDynamicPrompts_queryDynamicAudio_QueryResult=['Hello. My name is Joe.', 'Hello, my name is Bob']
    END_EXECUTION: Activities\CreateDynamicPrompts.comp - queryDynamicAudio - MF
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    We'll investigate this, thanks for reporting the bug.
    Is this happening when you try to expand a specific element in the tree? Or you get that expanding any element?
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Just the $callflow variables.
    I am in a sub component also.
  4. VAD_Support
    Aug 6, 2009
    690
    Thanks for the information, we'll investigate it and fix the problem.
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I have confirmed that pulling < and > characters from the database was breaking the User Interface, as well as creating a badfetch error. When I removed those I got past the error (although I needed those symbols in my query)
  6. VAD_Support
    Aug 6, 2009
    690
    OK, thanks for the additional information, this is very useful to fix the bug.
  7. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Now I get this problem. see attached.
  8. VAD_Support
    Aug 6, 2009
    690
    Are you in the same scenario than before? The error seems to be the same, right?
  9. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Similar, but no < or > characters this time
