Bug in V15 Mac and iOS Client
Discussion in 'Ideas' started by teknoit, Aug 2, 2016.
  1. teknoit
    Sep 30, 2015
    Had a fault where 'Cannot retrieve recordings Access denied', kept popping up.
    Checked all permissions etc with Andreas Psyllos. Please not we only use Macs and iPhones so never tested this on a Windows machine. Turns out that the fault is mac only related, if under Phone Provisioning 'show call recordings' is not highlighted then this message is thrown up, on a windows client you just get a blank window.
    So either needs a new message or somehow to switch of that curve ball.
    Cheers,
    Rich
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    I quite prefer the message.
    Access Denied - says exactly the issue. You do not have access.
    On Windows - to just show up blank - makes me think there are none.
