BUG: IVR Configuration error
Discussion in '3CX Phone System - General' started by tmyklebust, Jul 19, 2011.
  1. tmyklebust
    Feb 14, 2008
    5
    This is probably not the right place to report a bug, but I didn't find a better one right now. Hope it is ok.
    I just installed v10. Afterwards digital receptionists didn't work. After some research I found out that it was related to an incorrect configuration element in web.config in the ivr folder.
    <staticContent cacheControlMode="DisableCache" />
    Has to be (at least according to the documentation I found, and after the change it works):
    <staticContent><clientCache cacheControlMode="DisableCache" /></staticContent>
    Regards
    Terje Myklebust
    Faktum Software GmbH
